I’m trying to install Zorin OS to my PC onto a separate SSD. But I’m experiencing issues when trying to install.
I have a RTX 3070 as the GPU, so I’m trying to install using the Nvidia option. However, when selecting it, I’m only seeing my motherboard logo and nothing happens.
I tried doing the ”safe graphics” option and that seems to work.
Sorry, I'm a bit confused. But am I supposed to select which driver to use in some way? I've only downloaded the ISO and formatted a USB drive that I'm now booting the installer from, so I haven't done anything other than that. But I might be completely misunderstanding your question.
I get the black screen selecting the option "Try or Install Zorin OS (modern NVIDIA drivers)" from the initial menu when booting from the USB. I then instead tried the option "Try or Install Zorin OS (safe graphics)" and that worked. Although when I now try to boot the installed OS from the SSD I installed it to, I get the same problem again with the black screen.
The reason is that your card is so new. So with the commands @Aravisian showed you can get you into Graphic interface - Then you can install the latest nvidia driver.
Alright. In my case, it says "NVIDIA Corporation: Unknown" in the top, followed by: "This device is using a manually-installed driver". I remember seeing some message during the installation about detecting devices, could it be that the installer tried installing something based on what devices that were discovered during that?
The only option that is active is "Continue using a manually installed driver".
It also says "No proprietary drivers are in use" at the bottom.
I'll try the solution you suggested above in the terminal.
@Storm I didn't get any black screen and now when I look in the Software & Updates app, it says that I'm using "NVIDIA driver metapackage from nvidia-driver-535 (proprietary)".
So I guess that fixed it? It still says "NVIDIA Corporation: Unknown" at the top, but is that because it's too new for Zorin to recognise?
@Storm I'll try your suggestion, just wanted to provide some info that I found following the official guide for activating Nvidia here on zorin.com. I had a look under Settings > About and under Graphics it says "llvmpipe (LLVM 12.0.0, 256 bits)".
Also, during boot I noticed an error that says:
[drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[drm:nv_drm_probe_devices [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to register device
