Problems with driver installation
Newbie here. I'm having real problems with drivers when installing Zorin. Zorin installs, have no problem with that, but graphics & network are a headache. If I select 'update 3rd party etc while installing', the graphics returned are real ■■■■ & totally unusable. If I select 'update graphics before installing', the graphics are of such a low resolution, they are also unusable. If I simply install Zorin & forget graphics until installed, no network drivers are installed, which of course means I cannot get onto the web to update other drivers. I need some help/guidance please. I will admit at this point, I had problems with network drivers when loading my existing Windows 7. I had to download ISO after ISO until I found one that worked.
I'm loading Zorin OS 16 core X64.
My motherboard (if that helps with network drivers) is an Asrock FM2A68M-HD+
Networks drivers loaded are Realtek PCIe GBE Family Controller
Graphics = NVIDIA GeForce GT 630
Hope this helps.
I am trying to dual boot my existing Win 7 & Zorin. Once I have Zorin working the way I use my Win 7 & learnt the 'ins & outs', then I'll dedicate the whole drive & possibly update to Pro. I'm sorry, at present I cannot print from either system.
Can you please post the terminal output of
sudo lshw -c network
and
sudo lshw -c video
First may I say that I have not been ignoring anybody. Soon after this message was posted, the network adapter on my motherboard stopped working. I have repaired same by installing a network card that arrived today, which appears to be functioning correctly. As hardware has changed I am going to try a Zorin re-install to see if the card makes any difference.
