Good morning folks! Hou you've been?
I'm facing trouble when installin the FrF2 package on RStudio and I need it to a college class. When trying to install, the first error I found was this:
ERROR: compilation failed for package ‘lmtest’
* removing ‘/home/glhrmlz/R/x86_64-pc-linux-gnu-library/4.1/lmtest’
Warning in install.packages :
installation of package ‘lmtest’ had non-zero exit status
My professor saidi that lmtest is probably dependent for some Ubuntu package that is not on the system. Can someone help me on this? If not, I'll have to install some other distro on a VM.
That's it, Love y'all
The "lmtest" error is fixed, but I'm still getting this:
ERROR: dependency ‘igraph’ is not available for package ‘FrF2’
* removing ‘/home/glhrmlz/R/x86_64-pc-linux-gnu-library/4.1/FrF2’
installation of package ‘FrF2’ had non-zero exit status
Warning messages:
1: In utils::install.packages("igraph", repos = "https://cloud.r-project.org") :
installation of package ‘igraph’ had non-zero exit status
2: In utils::install.packages("FrF2", repos = "https://cloud.r-project.org") :
3: In utils::install.packages("FrF2", repos = "https://cloud.r-project.org") :
This is not a Zorin or a Linux Issue and Windows users suffer the same fate. The package developers sourced the wrong compiler and have not corrected it.
Hello, @Aravisian. Sorry for taking long to answer. I couldn't install the deb file you sent me, it says it has unmet dependencies, but does not show which one. My teacher told me that the problem could be a libcurl problem, so he told me to run this command:
sudo apt install libcurl4-openssl-dev
Even after this, the problem in RStudio went on. Now, the problem seems to be only with igraph. I tried installing it with pip as well, but I still can't install FrF2.
I wonder if a virtual machine would help me, at least til I write the script I need for my test.
I uhh... I appear to have made a mistake.
I thought I selected the amd64... I selected ARM64... Scientifically proving that I am a failure as a human being and that I deserve nothing less than ridicule and derision.
I ran the commands and the problem persists. This is the first time that I'm banging my head against the wall with a problem on Linux. I hope everything will be ok
