I downloaded and installed ProtonVPN from the Proton website and all seems to be working just fine - except for the fact that there is no menu selection in ProtonVPN to autostart when I fire-up the computer. It's a real pain to remember to manually start it every time. I'm totally new to Linux, coming from a Windows background. So how do I get a command in the startup for ProtonVPN?
Right click on Zorin menu ( bottom left of taskbar)
Edit menu.
Click on Internet in the left column.
Right click on Proton VPN.
Choose Properties.
Copy the Command string.
Close all of it down - that's all you needed from this part.
Again in the Zorin menu, search for Startup and choose Startup Applications.
Press Add.
Enter a name, the command string you've just copied, and a description.
Save.
Reboot and watch the magic.
Excellent! Thanks DavidA!
I see that you've solved your own problem. Nice one... ![]()
