Question about customizing the color of panel icons
I want to make each icon a different color.
We targeted the clipboard because it has a unique class compared to the other icons.
The problem is with the sound and network icons.
The battery icon was also targeted with this code:
panel .panel-button .power-status .system-status-icon,
panel .panel-button .system-status-icon.power-status {
color: #ff4444 !important;
And the new color was applied.
The problem is with the remaining icons, the sound and network icons.
What are their unique classes?
Does Zorin have a different structure than gnome-shell?
Note that the inspection tool's locking class feature doesn't work; instead, it selects all three icons under the class system-status-icon.
1000088174
I couldn't find any solution that worked.
Hello!
As I know, there is a heavy JS used in Zorin taskbar..
Most of styles are set through extension code (stage / etc)..
In example:
  • border radius of taskbar
  • or floating mode (margin)
  • icons hoover state (border radius)
Maybe you just need to "increase css specificity" by adding "more rules" to your css, in my case was like:
Specificity Calculation:
  • Inline styles: 1000 points
  • ID selectors: 100 points
  • Class/attribute/pseudo-class selectors: 10 points
  • Element selectors: 1 point
  • !important overrides everything (but specificity still matters for multiple !important rules)
So as example:
Selector Specificity Points
.quick-toggle 0-0-1-0 10
.quick-settings-grid .quick-toggle 0-0-2-0 20
.quick-toggle:hover 0-0-2-0 20
#panel .quick-toggle 0-1-1-0 110
.quick-settings .quick-toggle !important 0-0-2-0 20 + ∞
So:
  • If theme uses .quick-settings-grid .quick-toggle { border-radius: 12px !important; } -> (specificity 20 + ∞)
  • My css uses .quick-toggle { border-radius: 16px !important; }** (specificity 10 + ∞)
  • Theme wins because both have !important, and theme has higher base specificity!
Hope it is helpful!
Cheers!
