Question about wallpapers: Random Slideshow via Script possible?
Hi,
I have a few wallpapers which I want to have as a slideshow but with random “playback”.
I could not find any option in the settings (GNOME) and if I use Shotwell I can create a slideshow but I cannot set the playback to random.
So, my question is: Is there any possibility to get my wallpapers as a random slideshow? Maybe this is possible with a script?
Thank you very much for your hints!
You could try it with Variety.
Thank you!
Yes it works with Variety :grinning:
If you want to have a script look here:
https://forum.zorin.com/t/less-switchy-wallpaper-switcher/45142/9
Thanks a lot, that's what I was looking for, an easy "self-solution" :+1:
if you want to use timer for your script go here:
https://forum.zorin.com/t/script-to-create-timers/45797
Oh nice possibilities. I will have a look on it. Didn't know that you can create that much :grinning:
