Question Flatpak
I used flatpac to install minecraft bedrock launcher. Has been running fine! At the time software store did not list minecraft. Now, I see minecraft in the software store as available for install. The store does not know minecraft is installed. How do I fix this?
Thanks
FLATPAK's are completely separate from standard packages. This will explain why it doesn't show your FLATPAK. Its not a big deal, I am sure Synaptic Package Manager will show it if you had that installed and looked it up in a search.
Started to say does not show up in synaptic packages.. I guess It want hurt to install it again using the store?
Thanks
The Gnome-software store will still defer to Flatpak or Snap when it feels like it.
Fortunately, the ZorinGroup added an extension to the Gnome-software application that lists the source of the package you are viewing on the titlebar button labeled source.
beep beep...
I am a Maid-bot :robot:
Correction made in title.
flatpac ->Flatpak
beep beep...
Cleaning up the forum as she goes, where she ends up next, nobody knows. BEEP BEEP, thats FrenchPress, the awesome Maid Bot, with the pretty rainbow duster.
Marked solution. 268
