hello,
so i have tried removing packages using both apt purge and apt remove but i can still see some applications afterwards for example recently I installed lightdm using
sudo apt install lightdm
which i later uninstalled using
sudo apt purge lightdm
as well as
sudo apt remove lightdm
the output in terminal says that lightdm is not installed(after rerunning the above commands)
But i can sill see it in menu
And i can still open it(so its not just desktop icon)
So my question is why is this so? and what exactly is te function of the above two commands
additional info;
zorin os 16.2 core
i did setup lightdm as default login manger for some time
rightclicking on lightdm-->details-->remove in software center yields something along the lines "cannot remove package as it has unmet dependencies"
