Radeon HD 8570 artifacts with some applications
Hi
I have some trouble with slack, Vscode and Joplin : on startup, the app looks like this :
Then, the display blinks and the menus are misaligned with the mouse mouvements.
Is it related to the graphic card ? I installed Zorin core on an old computer with a Radeon HD8570.
Should I upgrade this hardware ? If yes, do you have any advice ? I have no specific requirements, just need hdmi and DP ports.
System runs in Wayland
lshw -C video :
       produit: Oland [Radeon HD 8570 / R5 430 OEM / R7 240/340 / Radeon 520 OEM]
       fabricant: Advanced Micro Devices, Inc. [AMD/ATI]
       identifiant matériel: 0
       information bus: pci@0000:01:00.0
       nom logique: /dev/fb0
       version: 00
       bits: 64 bits
       horloge: 33MHz
       fonctionnalités: pm pciexpress msi vga_controller bus_master cap_list rom fb
       configuration : depth=32 driver=radeon latency=0 mode=1920x1080 resolution=1920,1200 visual=truecolor xres=1920 yres=1080
       ressources : irq:38 mémoire:e0000000-efffffff mémoire:f7e00000-f7e3ffff portE/S:e000(taille=256) mémoire:c0000-dffff
Thanks
Hello,
Does this also happen in xorg display protocol?
No bugs with x11, only in wayland.
I'm going to stay with this protocol.
Thanks !
