Hi guys. Sometimes my Zorin OS Core just freeze and then after a while automatically reboot. So I want to know if there is a command to see the last reboot logs so I can figure out why is rebooting sometimes because it happens really randomly.
Hope someone can help me
In /var/logs
as well as Xsession errors in your Home Directory (reveal with ctrl+h if needed).
What graphics card are you using?
Other things to consider are issues with CPU Cooler, Failing PSU (Power Supply), BIOS update needed. I had similar issues in different OS and whilst working from home since lockdown until retirement I had forgotten to check for BIOS updates.
When I viewed the logs there was some reference to hardware (motherboard) so I checked my motherboard manufacturer's website for BIOS updates, avoiding the one that allows me to install Windows 11!
Is it overheating, check for bios update Are you using Nvidia GPU?
No, I'm an Intel dedicated user
