I got stuck on the part where you "Add the graphics software packages". As you can see in the screenshot, it just stopped. I'm not sure if it was supposed to do this.
Sometimes you need to give things time to install. Usually it should go back to the opening prompt (the one in green in screenshot) after completing installation. Once done, reboot before renaming back to Zorin and see if there is any improvement.
I've given it a few hours to install and nothing. Is there a shortcut/command like ctrl+c that retries the command or unpauses it? I haven't pressed ctrl+c. I was just hoping there was something like that.
Or maybe should I repaste part of the command? If so, which do I do?
EDIT: Nvm. I fixed it I think. I just needed to press enter. That's weird.
Alright. So I tried it and tested it. Looks like the problem is still there.
Here's the pics I was able to take. It's like this for a second and disappears or the whole horizontal part that has the delay disappears when I hover over it.
I'll undo the thing with nano tomorrow. But did I ever need to enable or disable anything for this to work properly? Or by installing the drivers it selected it automatically?
