Hello everyone, i installed zorin lite on very old laptop having 2gb ram, installation went fine, but now this problem is bothering me, many red circles appear following cursor path, their amount increases continuously, rendering keyboard useless.
That looks like the Locate Cursor
function gone haywire.
Can you please open Settings
, then navigate to Accessibility > Mouse
UNcheck the box for Find Cursor
Nope it has gone hurricane
If you are using laptop keyboard, you may turn the keyboard input for PC off and try some repairs like cleaning it.
