I'm running Zorin 17.1 Pro on a Proxmox server and am using RDP to access the instance. My question is whether or not it is possible to use/add dynamic resolution so I can easily adapt the screen size to my work environment.
Thanks!
ACB
Thanks!
ACB
I did a little more reading and it appears to be an issue with the screen share mode 'extend' not allowing connections.
