Realtek wifi network unclaimed Zorin 16.3
Connect with ethernet or phone hotspot.
git clone https://github.com/lwfinger/rtw89.git
cd rtw89
make
sudo make install
sudo modprobe rtw89pci
Yes, did that and got this
Instead try:
sudo apt install dh-sequence-dkms debhelper build-essential devscripts
git deborig HEAD
dpkg-buildpackage -us -uc
sudo apt install ../rtw89-dkms_1.0.2-3_all.deb
Another issue
I got those commands directly from the GitHub page I linked above.
Looking up dh-sequence-dkms, it looks like the package first appears in later versions of Ubuntu and in Sid.
I am in the middle of other work right now - please allow some time that I can look into this later or another forum member can provide some help.
Well, I know you are on the 6.3 kernel.
Can you also show the terminal output for
sudo lshw -C network
Hi,
Sorry for delay. I installed latest 16.3 pro version, but still no wifi .
Let's try
lspci
The lshw command gives a very generic response in this case.
And this is what I got on Arch
That shows RTL89... Which we tried in post 1 of this thread.
There is a minor difference: lwfingers is directed toward 8851... Your Arch screenshot shows 8852be
We can try:
#Turn off your Security Boot in BIOS
git clone https://github.com/HRex39/rtl8852be.git
cd rtl8852be
make -j8
sudo make install
sudo modprobe 8852be
Thanks, this working perfect. I got my wifi back :slight_smile:
What a difference a number makes...
Yeah :slight_smile:
