I have several VM's that run the lite and core. They all seem to have issues hanging on boot up with the Zorin logo. Also different systems local hardware on a NUC that the boots and anydesk just seems to go to a black screen. Just throwing that out there there is no way I can revert. Just making this post to see if anyone else is having any similar issues.
Sparkey
Are you using Virtual Box? I find virt-manager much better. No such issues running Zorin Core in virt-manager.
What do you use anydesk for? I read it is expensive to use to login to remote server. I preferred Remmina which is free. I could login directly to secure server connection with only one login needed. In VM of Windows 8 Pro I had to login three times in Edge!
In terms of updates are they pointing to 'Main Server'?
