I just bought Zorin 16.2 on the 30 November 2023. So less than 30 days ago.
Does I still need to purchase the version 17 ?
Thanks
Thanks
I recommend using your contact form to message the ZorinGroup directly.
They have many help requests and emails to get through, so please be patient. It can take a week for a response.
The ZorinGroup are very understanding and they know that users may choose Zorin Pro right before a release without realizing that the next release was looming.
You may consider registering for the Zorin OS newsletter:
Yeah, your best bet is to contact Zorin directly. As you bought it less than month ago, I dont see a reason why you shouldn't be able to do that.
In my case that is not possible for example, as I bought 16 pro on release day ![]()
Thanks. I have send a mail. I’m waiting for the answer.
