Hi there does anyone know what hardware is recommended, and not just the requirements?
Thanks.
For zorin lite 15.3
Hello and welcome to the forum
For Zorin 15,3 you could still use 32bit CPU.
The amount of memory, I recommend minimum 4GB.
It is possible to install it on 2GB RAM system but you would encounter a frustration for running some heavy apps.
