Hi, I've been asking questions about these QoL issues on Discord and Reddit, but haven't really found much relevant to solving these on Zorin. I used to have these issues on other Linux distros in the past, but can't remember how I solved them in the end.
How do I make the OS set and remember the default audio device between reboots/bootups? Currently it automatically selects my headset device.
Is it possible to make the OS remember window size and position between reboots/bootups? I was told it is possible on KDE desktop, but not sure if this can be done on Zorin.
Is there an app/GNOME extension/etc that would enable me to set typing delay on keyboard? The setting that governs how soon after pressing and holding a key you see the characters get typed.
Thanks in advance.
