The Goal:
I have two PC's each running ZORIN OS 16 core and each with package updates (as of 7 Dec 2021).
I am trying to set-up a remote desk top session using Remmina over SSH tunnel to the second machine. Both machines are currently on the same internal network, but the second machine will end up at my Fathers eventually.
The Problem:
I think my problem relates mainly to a lack of information and knowledge, specifically regarding Remmina and Zorin. I have setup remote desk top shares before, mainly between Windows machines and occasionally windows and Linux distros. So its not alien to me. But for some inexplicable reason I cannot crack a very basic set-up.
I think I can setup the SSH tunnel after installing OpenSSH on the remote PC. There are plenty of excellent YouTube tutorials.
Setting the firewall to allow connections (port 22) is not a problem. However port forwarding does not appear to be supported by default. Some pointers would be appreciated.
I think Remmina set-up should be relatively straightforward but I'm happy to accept your experience.
Now the confusing bit.
The Remmina YouTube tutorials show Ubuntu setups and nothing on Zorin. If I follow them then all I get is a Closed Connection error (both firewalls are disabled and the desktop share is setup on the remote machine). Since I get a Closed Connection error this suggests to me a VNC is running on the remote PC, strange since I haven't installed one and neither can I find one running. Since Zorin runs X11 I would have expected x11vnc to be installed. It is not.
So My questions:
- What, if any, VNC server is actually installed please?
- What is recommended?
