Hi,
I'm looking for the easiest / best way to setup remote desktop / screen sharing.
Currently i have enabled it on the machine running zorin os 16 pro in settings however i am having difficulty connecting.
Do these settings look correct? am i using the wrong client?
Also will this work over the internet if i portfoward whatever port this uses?
Remmina is an application that you can use to connect to a Remote desktop, it does not provide a server function for that.
If you would like to connect to your Zorin OS via remote, then the best and easiest way would be to instal VNC.
There is also a way to use RDP connection:
In case you want to connect to a server using RDP, then Remmina is the right application for that.
Port forwarding RDP ports is not recommended, because exposing RDP ports to the internet is a security risk. I would suggest you use a VPN server and client.
https://www.cyberciti.biz/faq/ubuntu-20-04-lts-set-up-openvpn-server-in-5-minutes/
system
Closed
August 1, 2022, 3:46pm
3
