Hello, Could you please explain me how to remove the battery icon in taskbar ? because I don't need it since i'm using dekstop PC. Thank you
I saw you're using zorin os core. I'm opening core in virtualbox and I'll show you how, then
@andreeewill try this solution:
https://extensions.gnome.org/extension/595/autohide-battery/
click 'click here to install browser extension', install the extension, reload the page, click on the switch to put it into ON, and click install. DONE!
