Render Problem
I'm writing to ask if anyone else is experiencing significant rendering and stuttering issues with certain applications on Zorin OS, using both X11 and Wayland.
Specifically, the problem occurs when I launch demanding creative applications like Kdenlive, Darktable, or DaVinci Resolve.
The system runs perfectly fine until I open one of these programs. Once open, the application itself immediately begins to stutter heavily, making it impossible to use. Crucially, this performance degradation then spreads, causing stuttering across the entire operating system, even after closing the application, until a full system restart.
Has anyone else encountered this similar system-wide performance breakdown when using these resource-intensive applications? Any suggestions or potential fixes would be greatly appreciated.
What's your computer specs? Also provide us with the output of this command;
sudo apt install inxi
inxi -Ga
I have moved this from Feedback to General Help, as OP is seeking a fix.
Are these Programs instelled as .deb/APT Packages, Snap or Flatpaks?
ill provide the output of "sudo apt install inxi
inxi -Ga" it as soon as possible, As for the installers, I tried deb and flatpack, I also have this stuttering problem with modirnth in appimg, in X11 it seems to be less.
