When you right-click on the taskbar/panel/dash there is a link for System Monitor. I appreciate this feature but wanted to find an improved version of this app and recently came across Mission Center, which seems to do a better job of grouping open applications together and also includes the ability to monitor the GPU.
I've set Mission Center to a new shortcut (Ctrl+Shift+Esc) so I can easily launch it that way but was wondering if there was a way to replace the existing GUI shortcut to launch Mission Center instead of System Monitor.
Did you grab Mission Center as a flatpak, snap, or AppImage? A flatpak should've made its own icon while installing, and I believe a snap would've, too. If you're using an appimage, you can make your own .desktop file, though I'm not familiar with the format. There's a tutorial on that here. It may be easier, if you're using the AppImage, to use GearLever. GearLever is available in the software store as a flatpak, and is a tool for managing AppImages.
Links for the convenience of anyone who might have a better grasp than me:
Mission Center (Available as flatpak, snap, or AppImage--can't be built from source on Zorin due to needing newer GTK and libadwaita.
Gear Lever (Even the build instructions only cover flatpak. Man.)
I went with the snap, but flatpak is also available from the software center. I don't think an icon is what I'm looking for, just needing to change the System Monitor link to point to Mission Center instead.
I don't think it would be easy to swap out existing controls but you could create a desktop shortcut:
Create Mission Center Shortcut
To create a shortcut to launch Mission Center on Ubuntu 22.04, you can follow these steps:
- Open a terminal and execute the following command to install Mission Center:
sudo snap install mission-center
Alternatively, if you prefer using Flatpak, you can install Mission Center with:
flatpak install flathub io.missioncenter.MissionCenter
- After installation, you can create a desktop shortcut for Mission Center. First, create a
.desktop
file for Mission Center. You can do this by opening a text editor and adding the following content:
[Desktop Entry]
Name=Mission Center
Exec=snap run mission-center
Icon=mission-center
Type=Application
Categories=Utility;System;
If you installed Mission Center via Flatpak, replace Exec=snap run mission-center
with Exec=flatpak run io.missioncenter.MissionCenter
Save the file with a .desktop
extension, for example, mission-center.desktop
Copy the .desktop
file to the ~/Desktop/
directory:
cp mission-center.desktop ~/Desktop/
- Right-click the newly created
.desktop
file on your desktop and select "Allow Launching" to make the shortcut usable.
Once you've completed these steps, you will have a desktop shortcut for Mission Center that you can use to quickly launch the application.
You could go to /usr/share/gnome-shell/extensions/zorin-taskbar@zorinos.com/
and take a Look in the Files if You can replace it. But please be very cautious with this. It is risky and could break the Taskbar.
Thanks, it looks like there is a file in there called appIcons.js where I could swap out the command, but its read-only and won't let me save or replace the file. I'm willing to give this a shot but the smart move is probably to fire up a VM and try it there so I don't end up having to do a full rebuild if something breaks.
To test it in a VM first is a good Idea.
For this open the Terminal and type sudo nano /usr/share/gnome-shell/extensions/zorin-taskbar@zorinos.com/appIcons.js
and then You can change it. After You've made the Change press ctrl+o to save the Change, Enter to confirm and ctrl+x to exit. then I would suggest to make a Reboot.
Thanks for those instructions, through my tinkering I went this route:
Open terminal: cd /usr/share/gnome-shell/extensions/zorin-taskbar@zorinos.com
sudo open appIcons.js
Replace 'gnome-system-monitor' with 'mission-center'
Save
Log out/log in or restart
Looks to be working without issue in the VM so I will do it on my main OS.
I went back and tried nano, but its kind of weird to work in there because its open within the terminal.
Another thing I noted is modifying this file seems like it would be a good method of adding or removing items from the list, or changing their order. I don't know if I would ever bother going that far, but good to know.
Also something I just noticed, if you right-click on the taskbar and select System Monitor and then right-click on the Zorin start icon and select System Monitor, those are two different links. So I will look into that further as I would want both to have the same behavior.
Okay so the other one is going to be:
cd /usr/share/gnome-shell/extensions/zorin-menu@zorinos.com
sudo open secondaryMenu.js
