After changing applications, icons and shell appearance will Restore Defaults resets the actual state? Dropdown menus seem broken so I don't change anything until I'm sure that I'll be able to undo the changes.
Yes, it should reset you to the default Zorin OS themes that you see in LiveUSB and after a fresh install.
hmmm?
Maybe broken isn't much correct, I just meant that, as you can see, they miss of their own related entry, I supposed to read something there.
