I lost the Zorin GUI desktop when I tried to eliminate the keyring password on the Edge browser. Through the help of person in this forum, I was able to restore the desktop, however, I can't see the external monitor nor does my Bluetooth external keyboard work anymore. Both used to. I'm using Zorin 16.3 Core.
If I try the command:
sudo apt remove --purge gnome-keyring
Here is the output the terminal gives:
bogofilter bogofilter-bdb bogofilter-common evolution-common gir1.2-gck-1 gir1.2-gcr-3
gir1.2-gdm-1.0 gir1.2-gnomebluetooth-1.0 gir1.2-graphene-1.0 gir1.2-mutter-7 gir1.2-rsvg-2.0
gir1.2-telepathyglib-0.12 gnome-keyring-pkcs11 gnome-shell-common gstreamer1.0-pipewire
libchamplain-0.12-0 libchamplain-gtk-0.12-0 libebackend-1.2-10 libebook-1.2-20
libebook-contacts-1.2-3 libedata-book-1.2-26 libedata-cal-2.0-1 libedataserverui-1.2-2
libevolution libgdm1 libgnome-autoar-gtk-0-0 libhandy-0.0-0 libmutter-7-0 libphonenumber7
libpipewire-0.3-0 libpipewire-0.3-modules libpst4 libpugixml1v5 libspa-0.2-modules
libtelepathy-glib0 libvncserver1 libytnef0 mutter-common p11-kit p11-kit-modules pipewire
pipewire-bin switcheroo-control touchegg xwayland
The following packages will be REMOVED:
chrome-gnome-shell evolution evolution-data-server evolution-ews evolution-plugin-bogofilter
evolution-plugin-pstimport evolution-plugins evolution-rss gdm3 github-desktop gnome-keyring
gnome-remote-desktop gnome-shell gnome-shell-extension-prefs
gnome-shell-extension-remove-dropdown-arrows gnome-shell-extension-x11gestures
gnome-shell-extension-zorin-appindicator gnome-shell-extension-zorin-desktop-icons
gnome-shell-extension-zorin-magic-lamp-effect gnome-shell-extension-zorin-menu
gnome-shell-extension-zorin-printers gnome-shell-extension-zorin-taskbar
gnome-shell-extension-zorin-window-move-effect gnome-shell-extensions
gnome-shell-extensions-zorin-desktop seahorse zorin-appearance-layouts-shell-core
zorin-desktop-session
As you can see, it will remove seahorse and all of the Zorin OS Desktop environment.
We also see that it renders a large number of libraries defunct including:
I do not know if you ran autoremove or not.
You might try
sudo apt install --reinstall bogofilter bogofilter-bdb bogofilter-common evolution-common gir1.2-gck-1 gir1.2-gcr-3 gir1.2-gdm-1.0 gir1.2-gnomebluetooth-1.0 gir1.2-graphene-1.0 gir1.2-mutter-7 gir1.2-rsvg-2.0 gir1.2-telepathyglib-0.12 gnome-keyring-pkcs11 gnome-shell-common gstreamer1.0-pipewire libchamplain-0.12-0 libchamplain-gtk-0.12-0 libebackend-1.2-10 libebook-1.2-20 libebook-contacts-1.2-3 libedata-book-1.2-26 libedata-cal-2.0-1 libedataserverui-1.2-2 libevolution libgdm1 libgnome-autoar-gtk-0-0 libhandy-0.0-0 libmutter-7-0 libphonenumber7 libpipewire-0.3-0 libpipewire-0.3-modules libpst4 libpugixml1v5 libspa-0.2-modules libtelepathy-glib0 libvncserver1 libytnef0 mutter-common p11-kit p11-kit-modules pipewire pipewire-bin switcheroo-control touchegg xwayland
Reboot and test. If still no good after that, please relay the terminal output for
sudo lshw -C video
and
sudo lshw -C network
Hi Aravisian,
I ran sudo apt autoremove and the sudo apt install --reinstall bogofilter...
The Bluetooth keyboard works now, but I'm still not seeing an option for an external monitor on the Settings-> Displays.
Here is the output for sudo lshw -C network
*-network
product: NetXtreme BCM57765 Gigabit Ethernet PCIe
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0f0
version: 10
serial: 40:6c:8f:29:db:9a
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=5.15.0-78-generic firmware=57765-v1.37 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 memory:a0400000-a040ffff memory:a0410000-a041ffff
*-network
product: BCM4331 802.11a/b/g/n
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 02
serial: 70:56:81:93:c6:65
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=10.0.0.57 latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:a0600000-a0603fff
I have Zorin installed on an old MacBook Pro (2012). The external monitor is connected via the Display Port and a converter to an HDMI cable.
Please show this output.
Bluetooth keyboard works now, but I still have the problem with no 2nd monitor detected.
Output for sudo lshw -C video:
*-display UNCLAIMED
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list
configuration: latency=0
resources: memory:a0000000-a03fffff memory:90000000-9fffffff ioport:2000(size=64) memory:c0000-dffff
Are you using Intel integrated card with Nvidia Dedicated?
If you do have Nvidia, please run in terminal:
sudo apt remove --purge '^nvidia-.*'
sudo apt update && sudo ubuntu-drivers install
Launch Software & Updates > `Additional Drivers tab and select the Nvidia Driver you wish to use.
Reboot once it is done loading to test.
I don't know whether I have dedicated Nvidia. I'll try the commands that you suggest. Couldn't hurt.
I don't think I have dedicated Nvidia. I ran the suggested remove command, and received the following output:
sudo apt remove --purge '^nvidia-,'
Reading package lists... Done
Building dependency tree
Note, selecting 'nvidia-kernel-common-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-535-server-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-325-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-346-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-binary' for regex '^nvidia-,'
Note, selecting 'nvidia-331-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-384-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-535-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-530-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-530-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-515-open' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-331-updates-uvm' for regex '^nvidia-,'
Note, selecting 'nvidia-cuda-toolkit-gcc' for regex '^nvidia-,'
Note, selecting 'nvidia-cg-toolkit' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-390' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-418' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-430' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-435' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-440' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-450' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-455' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-460' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-465' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-470' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-495' for regex '^nvidia-,'
Note, selecting 'nvidia-tesla-440-driver' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-535-server-open' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-510' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-515' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-520' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-525' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-530' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-535' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-icd-340-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-520-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-384-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-525-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver' for regex '^nvidia-,'
Note, selecting 'nvidia-367-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-515-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-535-server-open' for regex '^nvidia-,'
Note, selecting 'nvidia-modprobe' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-515-open' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-texture-tools' for regex '^nvidia-,'
Note, selecting 'nvidia-utils' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-387-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-legacy-340xx-vdpau-driver' for regex '^nvidia-,'
Note, selecting 'nvidia-349-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-530-open' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-535-server-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-535-server-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-535-open' for regex '^nvidia-,'
Note, selecting 'nvidia-firmware-535-535.86.05' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-zorin-live' for regex '^nvidia-,'
Note, selecting 'nvidia-310-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-331-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-525-open' for regex '^nvidia-,'
Note, selecting 'nvidia-prebuilt-kernel' for regex '^nvidia-,'
Note, selecting 'nvidia-legacy-304xx-vdpau-driver' for regex '^nvidia-,'
Note, selecting 'nvidia-vdpau-driver' for regex '^nvidia-,'
Note, selecting 'nvidia-legacy-390xx-opencl-icd' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-525-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-450' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-460' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-470' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1-331-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-510' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-515' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-525' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-535' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-390' for regex '^nvidia-,'
Note, selecting 'nvidia-smi' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-313-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-520-open' for regex '^nvidia-,'
Note, selecting 'nvidia-334-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-418' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-430' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-435' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-440' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-450' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-455' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-460' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-465' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-470' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-495' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-331-uvm' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-510' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-515' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-520' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-525' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-530' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-535' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-prime' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-390' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-firmware-535-535.54.03' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-418' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-430' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-435' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-440' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-450' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-455' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-460' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-465' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-470' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-515-open' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-495' for regex '^nvidia-,'
Note, selecting 'nvidia-current-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-340-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-510' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-515' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-520' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-525' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-530' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-535' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager' for regex '^nvidia-,'
Note, selecting 'nvidia-nsight' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-530-open' for regex '^nvidia-,'
Note, selecting 'nvidia-common' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-352-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-390' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-418' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-430' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-435' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-440' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-450' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-455' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-460' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-465' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-470' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-495' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-390' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-510' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-515' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-520' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-525' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-530' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-535' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-418' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-430' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-435' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-440' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-450' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-455' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-460' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-465' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-470' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-495' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-355-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-510' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-515' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-520' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-525' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-530' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-535' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-current' for regex '^nvidia-,'
Note, selecting 'nvidia-profiler' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-535-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-375-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-535-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-390' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-520-open' for regex '^nvidia-,'
Note, selecting 'nvidia-337-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-358-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-410' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-418' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-430' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-435' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-440' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-450' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-455' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-460' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-465' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-470' for regex '^nvidia-,'
Note, selecting 'nvidia-cuda-toolkit' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-495' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-510' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-515' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-520' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-525' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-530' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-535' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-common-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-378-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-450-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-340-updates-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-compute-utils-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-319-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-450' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-460' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-470' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-510' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-515' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-525' for regex '^nvidia-,'
Note, selecting 'nvidia-fabricmanager-dev-535' for regex '^nvidia-,'
Note, selecting 'nvidia-331-updates-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-440-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-530-open' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-525-open' for regex '^nvidia-,'
Note, selecting 'nvidia-visual-profiler' for regex '^nvidia-,'
Note, selecting 'nvidia-persistenced' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-520-open' for regex '^nvidia-,'
Note, selecting 'nvidia-settings-binary' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-520-open' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1-331' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1-340' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1-384' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-470-server' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-icd-331-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-510-server' for regex '^nvidia-,'
Note, selecting 'nvidia-304-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-535-server' for regex '^nvidia-,'
Note, selecting 'nvidia-340-uvm' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-390' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-515-open' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-460-server' for regex '^nvidia-,'
Note, selecting 'nvidia-egl-wayland-common' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-535-open' for regex '^nvidia-,'
Note, selecting 'nvidia-driver-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-418' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-430' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-435' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-440' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-450' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-455' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-460' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-465' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-470' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-495' for regex '^nvidia-,'
Note, selecting 'nvidia-cuda-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-no-dkms-525-server' for regex '^nvidia-,'
Note, selecting 'nvidia-cuda-doc' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-510' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-515' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-520' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-525' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-530' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-535' for regex '^nvidia-,'
Note, selecting 'nvidia-340-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-361-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-headless-515-server' for regex '^nvidia-,'
Note, selecting 'nvidia-cg-dev' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-cg-doc' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1' for regex '^nvidia-,'
Note, selecting 'nvidia-libopencl1-340-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-381-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-icd-331' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-icd-340' for regex '^nvidia-,'
Note, selecting 'nvidia-cuda-gdb' for regex '^nvidia-,'
Note, selecting 'nvidia-legacy-390xx-smi' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-304' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-icd-384' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-310' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-313' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-319' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-325' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-331' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-334' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-337' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-340' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-343' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-346' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-349' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-352' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-355' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-358' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-361' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-364' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-367' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-375' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-378' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-381' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-384' for regex '^nvidia-,'
Note, selecting 'nvidia-experimental-387' for regex '^nvidia-,'
Note, selecting 'nvidia-tesla-418-driver' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-525-open' for regex '^nvidia-,'
Note, selecting 'nvidia-343-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-364-updates' for regex '^nvidia-,'
Note, selecting 'nvidia-304' for regex '^nvidia-,'
Note, selecting 'nvidia-310' for regex '^nvidia-,'
Note, selecting 'nvidia-313' for regex '^nvidia-,'
Note, selecting 'nvidia-319' for regex '^nvidia-,'
Note, selecting 'nvidia-325' for regex '^nvidia-,'
Note, selecting 'nvidia-331' for regex '^nvidia-,'
Note, selecting 'nvidia-334' for regex '^nvidia-,'
Note, selecting 'nvidia-337' for regex '^nvidia-,'
Note, selecting 'nvidia-340' for regex '^nvidia-,'
Note, selecting 'nvidia-343' for regex '^nvidia-,'
Note, selecting 'nvidia-346' for regex '^nvidia-,'
Note, selecting 'nvidia-349' for regex '^nvidia-,'
Note, selecting 'nvidia-352' for regex '^nvidia-,'
Note, selecting 'nvidia-355' for regex '^nvidia-,'
Note, selecting 'nvidia-358' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-390' for regex '^nvidia-,'
Note, selecting 'nvidia-361' for regex '^nvidia-,'
Note, selecting 'nvidia-364' for regex '^nvidia-,'
Note, selecting 'nvidia-367' for regex '^nvidia-,'
Note, selecting 'nvidia-375' for regex '^nvidia-,'
Note, selecting 'nvidia-378' for regex '^nvidia-,'
Note, selecting 'nvidia-381' for regex '^nvidia-,'
Note, selecting 'nvidia-384' for regex '^nvidia-,'
Note, selecting 'nvidia-387' for regex '^nvidia-,'
Note, selecting 'nvidia-dkms-kernel' for regex '^nvidia-,'
Note, selecting 'nvidia-390' for regex '^nvidia-,'
Note, selecting 'nvidia-firmware-535-server-535.54.03' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-418' for regex '^nvidia-,'
Note, selecting 'nvidia-utils-418-server' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-430' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-435' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-440' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-450' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-455' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-460' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-465' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-470' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-495' for regex '^nvidia-,'
Note, selecting 'nvidia-settings' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-510' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-515' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-520' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-525' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-530' for regex '^nvidia-,'
Note, selecting 'nvidia-kernel-source-535' for regex '^nvidia-,'
Note, selecting 'nvidia-opencl-icd' for regex '^nvidia-,'
Note, selecting 'nvidia-settings' instead of 'nvidia-settings-binary'
Package 'nvidia-vdpau-driver' is not installed, so not removed
Package 'nvidia-legacy-340xx-vdpau-driver' is not installed, so not removed
Package 'nvidia-legacy-304xx-vdpau-driver' is not installed, so not removed
Package 'nvidia-390' is not installed, so not removed
Package 'nvidia-304' is not installed, so not removed
Package 'nvidia-libopencl1-dev' is not installed, so not removed
Package 'nvidia-libopencl1' is not installed, so not removed
Package 'nvidia-current' is not installed, so not removed
Package 'nvidia-current-updates' is not installed, so not removed
Package 'nvidia-driver-410' is not installed, so not removed
Package 'nvidia-387' is not installed, so not removed
Package 'nvidia-387-updates' is not installed, so not removed
Package 'nvidia-experimental-387' is not installed, so not removed
Package 'nvidia-384-updates' is not installed, so not removed
Package 'nvidia-experimental-384' is not installed, so not removed
Package 'nvidia-381' is not installed, so not removed
Package 'nvidia-381-updates' is not installed, so not removed
Package 'nvidia-experimental-381' is not installed, so not removed
Package 'nvidia-378' is not installed, so not removed
Package 'nvidia-378-updates' is not installed, so not removed
Package 'nvidia-experimental-378' is not installed, so not removed
Package 'nvidia-375' is not installed, so not removed
Package 'nvidia-375-updates' is not installed, so not removed
Package 'nvidia-experimental-375' is not installed, so not removed
Package 'nvidia-367' is not installed, so not removed
Package 'nvidia-367-updates' is not installed, so not removed
Package 'nvidia-experimental-367' is not installed, so not removed
Package 'nvidia-364' is not installed, so not removed
Package 'nvidia-364-updates' is not installed, so not removed
Package 'nvidia-experimental-364' is not installed, so not removed
Package 'nvidia-361' is not installed, so not removed
Package 'nvidia-361-updates' is not installed, so not removed
Package 'nvidia-experimental-361' is not installed, so not removed
Package 'nvidia-358' is not installed, so not removed
Package 'nvidia-358-updates' is not installed, so not removed
Package 'nvidia-experimental-358' is not installed, so not removed
Package 'nvidia-355' is not installed, so not removed
Package 'nvidia-355-updates' is not installed, so not removed
Package 'nvidia-experimental-355' is not installed, so not removed
Package 'nvidia-352' is not installed, so not removed
Package 'nvidia-352-updates' is not installed, so not removed
Package 'nvidia-experimental-352' is not installed, so not removed
Package 'nvidia-349' is not installed, so not removed
Package 'nvidia-349-updates' is not installed, so not removed
Package 'nvidia-experimental-349' is not installed, so not removed
Package 'nvidia-346' is not installed, so not removed
Package 'nvidia-346-updates' is not installed, so not removed
Package 'nvidia-experimental-346' is not installed, so not removed
Package 'nvidia-343' is not installed, so not removed
Package 'nvidia-343-updates' is not installed, so not removed
Package 'nvidia-experimental-343' is not installed, so not removed
Package 'nvidia-experimental-340' is not installed, so not removed
Package 'nvidia-337' is not installed, so not removed
Package 'nvidia-337-updates' is not installed, so not removed
Package 'nvidia-experimental-337' is not installed, so not removed
Package 'nvidia-334' is not installed, so not removed
Package 'nvidia-334-updates' is not installed, so not removed
Package 'nvidia-experimental-334' is not installed, so not removed
Package 'nvidia-experimental-331' is not installed, so not removed
Package 'nvidia-325' is not installed, so not removed
Package 'nvidia-325-updates' is not installed, so not removed
Package 'nvidia-experimental-325' is not installed, so not removed
Package 'nvidia-319' is not installed, so not removed
Package 'nvidia-319-updates' is not installed, so not removed
Package 'nvidia-experimental-319' is not installed, so not removed
Package 'nvidia-313' is not installed, so not removed
Package 'nvidia-313-updates' is not installed, so not removed
Package 'nvidia-experimental-313' is not installed, so not removed
Package 'nvidia-310' is not installed, so not removed
Package 'nvidia-310-updates' is not installed, so not removed
Package 'nvidia-experimental-310' is not installed, so not removed
Package 'nvidia-304-updates' is not installed, so not removed
Package 'nvidia-experimental-304' is not installed, so not removed
Package 'nvidia-egl-wayland-common' is not installed, so not removed
Note, selecting 'libnvtt-bin' instead of 'nvidia-texture-tools'
Package 'nvidia-legacy-390xx-opencl-icd' is not installed, so not removed
Package 'nvidia-legacy-390xx-smi' is not installed, so not removed
Package 'nvidia-driver' is not installed, so not removed
Package 'nvidia-tesla-440-driver' is not installed, so not removed
Package 'nvidia-tesla-418-driver' is not installed, so not removed
Package 'nvidia-prime' is not installed, so not removed
Package 'nvidia-settings' is not installed, so not removed
Package 'nvidia-firmware-535-535.54.03' is not installed, so not removed
Package 'nvidia-compute-utils-418' is not installed, so not removed
Package 'nvidia-dkms-418' is not installed, so not removed
Package 'nvidia-driver-418' is not installed, so not removed
Package 'nvidia-headless-418' is not installed, so not removed
Package 'nvidia-headless-no-dkms-418' is not installed, so not removed
Package 'nvidia-kernel-common-418' is not installed, so not removed
Package 'nvidia-kernel-source-418' is not installed, so not removed
Package 'nvidia-utils-418' is not installed, so not removed
Package 'nvidia-cg-dev' is not installed, so not removed
Package 'nvidia-cg-doc' is not installed, so not removed
Package 'nvidia-cg-toolkit' is not installed, so not removed
Package 'nvidia-cuda-dev' is not installed, so not removed
Package 'nvidia-cuda-doc' is not installed, so not removed
Package 'nvidia-cuda-gdb' is not installed, so not removed
Package 'nvidia-cuda-toolkit' is not installed, so not removed
Ok, let's try
sudo apt install --reinstall xserver-xorg-video-intel linux-generic-hwe-20.04
Once done, reboot and test...
Thanks for your help, but I decided to reinstall Zorin. Everything is back to the way it should be.
Thanks for the advice.
