Restore zorin 17 by using cmd
By mistake I made some settings and now I cannot see the desktop icons viz zorin, brave browser, files icon , etc . The desktop is clean with only background image. I am unable to manoeuvre or shut down . Is there any way out
. Please help
Can you open the terminal with CTRL+Alt+T
and enter
"sudo reboot"
here? Perhaps it helps. If after reboot still is no desktop, open terminal again and enter
"sudo apt install --reinstall zorin-os-lite-desktop"
What exactly did You do?
Blockquote
I hàve installed zorin os 17.3 core not lite.
Now what is the command to use
Ok tell me how to shut down / power off.
In Zorin core the command is
"sudo apt install --reinstall zorin-os-desktop"
Please correct your Zorin forum profile -lite is indicated there.
Can't you open the terminal with the shortcut?
To shutdown enter
"sudo shutdown -h now"
Tell me how to uninstall the os completely from hdd. And I . will install zorin os with my pendrive
When You want install only Zorin on Your Machine, you can start the USB Stick with Zorin on it and during the Installation, choose the ''Erase disk'' Option. Then it will completely wipe Your HDD. All on it will be deleted. Or do You have a dual-Boot System?
Patrick, Your forum profile says you are using "Lite".
If you are now using "Core", then please edit your profile accordingly, to avoid misunderstanding. Thanks.
I have solved my problem by installing zorin via usb bootable. Please close the topic
Topic closed per O.P.'s request.
