Root has Low Disk Space
Zorin 16 Lite is OK and what I use, uses Partition 1, 4, and 6. Zorin 16 Gnome uses Partition 1, 3, 4, and 5.
I moved all of the Free Space except for 15 GB into Partition 6. This 15 GB free space is left of Partition 3 Size 40 GB and is the Partition that is Low Space and is used by Zorin 16 Gnome. 40 GB Swap Partition is on the right of Partition 3.
How can I either move the 15 GB of free space into Partition 3 or take 10 GB from 40 GB Swap Partition to Partition 3. Or do I need the Swap file?
I do not find a label field that is blank.
My boot menu has Zorin 16.1 how did that get updated?
I notice Zorin 16.2 is out and I downloaded it. Can these be installed without loosing and personal data?
I have a 40 GB swap file Partition 4. I do not Hibernate so can I do away with this partition and move the space to Partition 3 where the space is needed?
I need to make a Backup of the system. Where is the app or how do I make a Backup?
For DejaDup, just type backups in your app menu.
Or if using Timeshift or rescuezilla, follow the normal steps you take when using those (since you would have had to install and configure them).
I use neither... I just compress my home folder and save it on another disk.
Understand all except "clear the mount at boot" How do I do this?
If you remove a partition that is included in the file system table (fstab), you must clear it out of fstab in order to avoid it remounting that partition at boot or throwing errors if you have changed that partition or removed it.
You can access and remove the UUID line of the Swap Parttion in fstab with
sudo nano /etc/fstab
How do you compress your Home folder?
There are many ways...
Terminal:
sudo tar -cvpJf backuphome.tar.xz /home/$USER
Or, you can use your file manager by elevating, then navigating from root to /home. Then right click your UserName Folder and choose "Compress"
I personally only back up individual directories and files that I know to keep.
So, I do not compress all of /home/$USER. I just launch the file manager, and right click the individual directories and files that I wish to keep.
Be advised: Compression can take a while.
