Hello, I am a very new Zorin and overall Linux user in general but am loving it so far. However, I am downloading all of the old applications I used on my previous OS (windows) and have downloaded two (KeyPass and StandardNotes) application which are just basic applications for notes and a password manager. However whenever I try to open to use them I get a popup that ask if I was to run or display its contents with the options to execute, show, or execute in terminal. I just want them to open automatically every time I click on it and be not have this pop up. If anyone can help me that would be great, thanks.
Hello @linuxnoobz , welcome to the community ![]()
Can you add a bit more information how did you install them?
In Linux world there are different package managers to install apps, Zorin mainly uses these 3 apt, flatpak, snap. As far as I know if you install an app from these, then you don't get any additional pop up unless it's an inbuilt feature of the installed app itself.
I suspect if you have installed those mentioned apps in Windows way(from a .exe file) then that might be the reason for the pop ups.
It's treating those files as "executable text files".
In Terminal, enter:
sudo nautilus
When Nautilus pops up, click the 'down arrow' button at top-right, select "Preferences", go to the "Behavior" tab, select "Display them".
Then, right-click the file you want to open and select the correct program to open them in... Zorin OS should open them in that program thereafter.
Well the main thing I am using and having this issue with is KeePassXC. I went to their official site (Download – KeePassXC) and just hit download. From there I went into downloads from files and dragged the icon over to my desktop and it does not even have an image. Same for StandardNotes (https://standardnotes.com) and both have this annoying popup and no icon and it is really annoying me. I tried what the other comment said and still nothing. Let me know if you have any further suggestions or if I can use terminal to install this or fix this and just delete and redownload them. Thank you so much.
Well the main thing I am using and having this issue with is KeePassXC. I went to their official site (Download – KeePassXC) and just hit download. From there I went into downloads from files and dragged the icon over to my desktop and it does not even have an image. Same for StandardNotes (https://standardnotes.com) and both have this annoying popup and no icon and it is really annoying me. I tried what you said and still nothing. Let me know if you have any further suggestions or if I can use terminal to install this or fix this and just delete and redownload them. Thank you so much.
How do I know what would be the correct program to open them in? Complete noob am very sorry....I have been having this issue with a lot of my applications I download. The only success I have had with downloading applications and them having an actual icon and opening without the pop-up is if I just download it from terminal directly.
this is exactly what it is doing
I think KeePassXC is listed in the Software Store as an apt, or at least it was in the past.
So you can simply install it from there.
For KeePassXC, you can install right from the Software Store or through the terminal: sudo apt install keepassxc.
For StandardNotes, the only option seems to be the AppImage format. (There's also a Flatpak that can be installed through the Software Store) Did you follow the instructions listed below in the download page? Open a terminal and copy/paste them, pointing to the executable file to grant permissions. You may need to prefix that command with sudo: sudo chmod a+x ~/Download/standard-notes....
Alternatively, right-click on the file -> properties -> permissions -> allow executing file as program.
If you still have issues, right-click -> open with... -> "install Linux Application" should do the trick.
That was me, posted how to fix haha I made the same change, then forgot where it was. Should help ![]()
As a beginner you can use the Software Store to install apps.
I didn't realize that Standard Notes has a flatpak available as well. That should make it easy enough to install both of them through there, although given it's Flatpak some adjustments may be needed.
