Last night I loaded zorin16 core, downloaded MT4 from broker. When opening it, zorin recognized file type, loaded windows app support, fired up my platform, perfect. Being sold, I then went and bought Pro version, did all above steps, when zorin tried to load windows app support, an error came up, "package dependencies cannot be resolved" Underneath it says" this error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time". I've loaded PRO version 3 times, same every time. If I can't run MT4 in Pro, I'll stay with core. Please advise.
Please open a terminal with ctrl+alt+t
Paste each of these in:
sudo dpkg --configure -a
Hit enter
. Then
Once this is done, please try installing the .exe package. If it fails, in terminal run:
sudo dpkg --add-architecture i386
sudo apt install zorin-windows-app-support
Then install the .exe application.
