In Windows, I used to run npm in Visual Studio Code. But now I'm unsure why the command is not detected in VSC. I confirm that I have installed both npm and node.
I googled around, and it seems to be something to do with my VSC terminal no longer has the Powershell option, it is now Bash. Anyone has any experience with this?
Sorry, I'm new to Linux but I'm in love with Zorin and won't mind learning what's needed to make it work.
It is installed - we can see your evidence of that. I would suggest checking your path set for nodejs and npm in vscode. It is the only thing I can think of off the top of my head that could cause npm command to not be recorgnized.
thanks a lot for the direction. I found the problem. I removed the installation (which I installed from Software in Zorin — I think it is flatpak), and downloaded the deb version from Visual Studio website. Hmm.. it looks like some software may not work properly If downloaded from sources other than its original one.
Thanks for your pointer. Without which, I am still trying to investigate the NPM portion
@337harvey Is correct, this issue is is well known when installing VSCode as a flatpak as the integrated terminal does not have full access to the system. Installing through apt should do the trick. I would also suggest using VSCodium instead, which is VSCode sans the telemetry.
Make sure to follow the instructions from the Node.js website for Ubuntu and Ubuntu-based distributions, as otherwise the version of Node.js will likely be severely out of date.
Thanks @zenzen, my version is indeed severely outdated when I first did an apt install. It is at the latest version now after I followed the instruction.
Also, thanks to @337harvey , for the information. I will also check out VSCodium.
