Samsung ML3310ND - Zorin Pro 18 - Feint text
Hi there
Just need a pointer to the recommended installation suggestions for the above printer.
It was recognised during the OS install and prints fine, except the density/darkness is too feint.
Not sure where to go, since the 'test page' print option from the Zorin printers settings is perfect, gives a set of differing density's.
The 'toner saver' is disabled in the printer's own setup, and the printers own test page is fine.
Ideas anyone?
cheers CD
edit - Zorin 17 core has a different interface and works fine.
v18 Pro
Hi there, sorted it.
FYI - downloaded the driver from the support website (uld_V1.00.39_01.17.tar.gz) and ran the install.sh as Superuser.
Only one instance was installed and I get control of the density.
cheers CD
