Saving joystick settings on Retroarch
Hi everyone. I'm using Retroarch (flatpack version on Software). The program recognizes my arcade stick (Krom) every time as another controller (in most cases as Nintendo Switch Pro Controller) and i cannot save the joystick configuration settings because Retroarch reports an error on saving so i must configure input every time i open Retroarch. What can i do?
IS retroarch set up correctly with flatseal? IF not I would check that first.
I think that i'll try the other version on Software because modifing various settings on Flatseal does not solve the problem
The Zorin Os version on Software does not work on my system. I will reinstall the Flatpack version and eventually i will configure joystick every time. Thanks anyway.
