Scale larger than 100% in 1920x1080 and couldn't even use 1280x720 at all. right clicking the screen to adjust anything is impossible because the menu doesn't fit in the window. I haven't installed it on my computer yet because of this.
Welcome! Scaling and screen resolution are not the same. My only option was 200%, I couldn't use it. So I made everything I could bigger, like text.
Be be precise here: You take about the common Scaling, yes? Can You maybe make a Picture of it so we can see what You mean?
Its likely the same problem I have. Anyone who uses high definition displays, in the 4K variety, will suffer eye strain, especially those who have poor vision from the start.
I know how @Odismilo feels.
Its just a reality for anyone who pushes greater then 1080P resolutions. Linux have always been terrible at display scaling with resolutions, its one of my largest gripes with Linux. And don't blame 4K either, its nothing new, and has been a thing for at least 13-years, no excuse for garbage scaling. But this is where we are, and the only choice, is to push 200% scale.
