so i wanted to use scrcpy but it simply wont work heres the error . btw i also installed the latest platform tools and tried form there... i got the same error
* daemon not running; starting now at tcp:5037
ADB server didn't ACK
Full server startup log: /tmp/adb.1000.log
Server had pid: 37040
--- adb starting (pid 37040) ---
adb I 06-03 17:21:02 37040 37040 main.cpp:57] Android Debug Bridge version 1.0.39
adb I 06-03 17:21:02 37040 37040 main.cpp:57] Version 1:8.1.0+r23-5ubuntu2
adb I 06-03 17:21:02 37040 37040 main.cpp:57] Installed as /usr/lib/android-sdk/platform-tools/adb
error: could not install *smartsocket* listener: Address already in use
* failed to start daemon
adb: error: failed to get feature set: cannot connect to daemon
ERROR: "adb push" returned with value 1
also heres the adb logcat
adb logcat
Server had pid: 37054
--- adb starting (pid 37054) ---
adb I 06-03 17:22:18 37054 37054 main.cpp:57] Android Debug Bridge version 1.0.39
adb I 06-03 17:22:18 37054 37054 main.cpp:57] Version 1:8.1.0+r23-5ubuntu2
adb I 06-03 17:22:18 37054 37054 main.cpp:57] Installed as /usr/lib/android-sdk/platform-tools/adb
- waiting for device -
Server had pid: 37070
--- adb starting (pid 37070) ---
adb I 06-03 17:24:29 37070 37070 main.cpp:57] Android Debug Bridge version 1.0.39
adb I 06-03 17:24:29 37070 37070 main.cpp:57] Version 1:8.1.0+r23-5ubuntu2
adb I 06-03 17:24:29 37070 37070 main.cpp:57] Installed as /usr/lib/android-sdk/platform-tools/adb
error: cannot connect to daemon
Name Version Rev Tracking Publisher Notes
bare 1.0 5 latest/stable canonical** base
core18 20230503 2751 latest/stable canonical** base
core22 20230503 634 latest/stable canonical** base
gnome-3-28-1804 3.28.0-19-g98f9e67.98f9e67 198 latest/stable canonical** -
gnome-42-2204 0+git.587e965 102 latest/stable canonical** -
gtk-common-themes 0.1-81-g442e511 1535 latest/stable canonical** -
snapd 2.59.4 19361 latest/stable canonical** snapd
flatpak list
Name Application ID Version Branch Origin Installation
Google … com.google.Chrome 113.0.5672.126-1 stable flathub system
Whatsie com.ktechpit.whatsie 4.14 stable flathub system
Extensi… …an.ExtensionManager 0.4.0 stable flathub system
Freedes… …reedesktop.Platform 22.08.12.1 22.08 flathub system
Mesa …Platform.GL.default 23.1.1 22.08 flathub system
Mesa (E… …Platform.GL.default 23.1.1 22.08-extra flathub system
nvidia-… …L.nvidia-470-182-03 1.4 flathub system
openh264 …p.Platform.openh264 2.1.0 2.2.0 flathub system
GNOME A… org.gnome.Platform 43 flathub system
ZorinBl… …heme.ZorinBlue-Dark 3.22 zorinos system
ZorinBl… …eme.ZorinBlue-Light 3.22 zorinos system
ZorinGr… …eme.ZorinGreen-Dark 3.22 zorinos system
ZorinGr… …me.ZorinGreen-Light 3.22 zorinos system
ZorinGr… …heme.ZorinGrey-Dark 3.22 zorinos system
ZorinGr… …eme.ZorinGrey-Light 3.22 zorinos system
ZorinOr… …me.ZorinOrange-Dark 3.22 zorinos system
ZorinOr… …e.ZorinOrange-Light 3.22 zorinos system
ZorinPu… …me.ZorinPurple-Dark 3.22 zorinos system
ZorinPu… …e.ZorinPurple-Light 3.22 zorinos system
ZorinRe… …theme.ZorinRed-Dark 3.22 zorinos system
ZorinRe… …heme.ZorinRed-Light 3.22 zorinos system
KDE App… org.kde.Platform 5.15-22.08 flathub system
QGnomeP… …heme.QGnomePlatform 5.15-22.08 flathub system
QGnomeP… …Platform-decoration 5.15-22.08 flathub system
ONLYOFF… …fic.desktopeditors 7.3.3 stable flathub system
yes i have the .android directory.... also i tried the wireless way but i get this
/adb connect 192.168.0.102
adb server version (39) doesn't match this client (41); killing...
* daemon started successfully
connected to 192.168.0.102:5555
platform-tools|⇒ scrcpy
INFO: scrcpy 1.12.1 <https://github.com/Genymobile/scrcpy>
adb server version (41) doesn't match this client (39); killing...
/usr/share/scrcpy/scrcpy-server: 1 fil...shed. 2.8 MB/s (24773 bytes in 0.008s)
INFO: Initial texture: 1080x2400
[server] ERROR: Exception on thread Thread[main,5,main]WARN: Device disconnected
are there any good alternatives to this? for the time being atleast i could do some progress in my work.
so i deleted the .android folder rebooted and tried scrcpy i get this
/usr/share/scrcpy/scrcpy-server: 1 fil...shed. 1.3 MB/s (24773 bytes in 0.018s)
java.lang.AssertionError: java.lang.reflect.InvocationTargetException
at com.genymobile.scrcpy.wrappers.SurfaceControl.setDisplaySurface(SurfaceControl.java:75)
at com.genymobile.scrcpy.ScreenEncoder.setDisplaySurface(ScreenEncoder.java:178)
at com.genymobile.scrcpy.ScreenEncoder.streamScreen(ScreenEncoder.java:70)
also why doesnt zorin come with the latest adb version? and how can i replace the default platform tools with the latest one i downloaded
appreciate your help guys <3
i don't know u r trying to use scrcpy by using usb cable or u r trying wireless connection?
I think there is no problem when using usb cable that support transfer data, u just need to enable debug mode in ur phone.
if the problem in using scrcpy in wireless mode, u need to pair ur pc with ur phone using the command adb pair.
adb pair command not supported in the version used by zorin and scrcpy.
so the steps will be:
1- install the last adb version that support pair command
2-go to ur phone and enable wirless dubg
3-open terminal in the folder that has adb that u downloaded, and type that in terminal: ./adb pair ip address phone
4-go to ur phone and in wirless dubg u will see ur pc is paring with ur phone, get the port from the info in that filed and use it in the following commands ./adb connect 192.168.1.5:port(note: ur will use ip of ur phone and the port that u will find it in wireless debug field) ./adb tcpip port adb connect 192.168.1.5:port(note:u will use the old version here) scrcpy
I am sorry, I cannot explain the steps because the steps are dependent on your setup.
I do not know the path without having access to your computer. But you can look for and identify the path.
Check GenyMotion settings -> ADB tab and check if you need to set a custom path that directs to Scrcpy
Or try emulating what this poster did:
In my case this error occured when I set up my environment adb path as ~/.android-sdk/platform-tools (which happens when e.g. android-platform-tools is installed via homebrew), which version was 36, but Android Studio project has Android SDK next path ~/Library/Android/sdk which adb version was 39.
I have changed my PATH to platform-tools to ~/Library/Android/sdk/platform-tools and error was solved
Look in the relevant folders in your Home Directory and see what paths are being directed in your settings.
