Scrcpy worked with u?
I don't know why that app doesn't work with me, i did all steps, enable usb debugging mode in my mobile and connect ,but it show always device offline
adb server version (41) doesn't match this client (39); killing...
* daemon started successfully
adb: error: failed to get feature set: no devices/emulators found
ERROR: "adb push" returned with value 1
no, i think that anthor problem here, my usb cable can only charge my phone when link usb in pc, even if i changing the usb mode, so i think i can't connect with usb
to connect by wifi, i need first to connect with usb in the initialization.
if i want to get the initialization without usb, i need to pair phone with pc by enabling wireless debugging,the version of adb in zorin doesn't have option of pairing
I think scrcpy need to adb version 39 which zorin has it,but doesn't support adb pair, adb version 41 has pair, but can't support scrcpy
ok, i solved it , i didn't need to using usb , i installed adb last version 41(which has pairing) beside the adb version of zorin 39,
eid@eid-HP-Compaq-6005-Pro-SFF-PC:~/platform-tools$ ./adb connect  192.168.1.5:39409
connected to 192.168.1.5:39409
eid@eid-HP-Compaq-6005-Pro-SFF-PC:~/platform-tools$ ./adb tcpip 39409
restarting in TCP mode port: 39409
eid@eid-HP-Compaq-6005-Pro-SFF-PC:~/platform-tools$ adb connect  192.168.1.5:39409
eid@eid-HP-Compaq-6005-Pro-SFF-PC:~/platform-tools$ scrcpy
INFO: scrcpy 1.12.1 <https://github.com/Genymobile/scrcpy>
/usr/share/scrcpy/scrcpy-server: 1 fil...shed. 0.4 MB/s (24773 bytes in 0.055s)
INFO: Initial texture: 720x1520
i tried another USB cable which enable data transfer and worked good without internet, so u should sure that USB is for data transfer, if not u can use my method in the solution which u must pair phone with pc using the command of adb pair <ip address phone>
