sudo apt install firmware-b43-installer
sudo apt install linux-firmware && sudo reboot
If you have no Ethernet connection... Let me know...
I tried the first and got this -
mac@mac-MacBookPro:~$ sudo apt install firmware-b43-installer
[sudo] password for mac:
Reading package lists... Done
Building dependency tree
E: Unable to locate package firmware-b43-installer
*** Then I tried the first part of your second line and got this
mac@mac-MacBookPro:~$ sudo apt install linux-firmware
linux-firmware is already the newest version (1.173.19).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
*** If I'm right that means the correct driver is already there?
But I have no ethernet - and when I look at the options in the bottom right network connection section the ethernet bits are still greyed out.
One interesting things - when I get to the boot screen it gave me 2 options - one was zorin and one was zorin with advanced options. I have never seen those 2 options before. When Ive booted before it just booted.... so why 2? I'm going to try booting advanced and see what happens...
Its so weird as I was able to install the Broadcom drivers as part of the 2 required prop drivers before...
But as before when I search for additional drivers the Broadcon wifi ones dont come up - like they are not needed - or the hardware doesnt exist... but yet we know they are there...
This is why you got:
The above commands are based on you using Ethernet to access the web to install the packages.
Here is a link to the .deb file - you can download it on a working computer, then transfer it via usb and install it.
http://archive.ubuntu.com/ubuntu/pool/multiverse/b/b43-fwcutter/firmware-b43-installer_019-4_all.deb
I will try it again - I was using tethered internet from my phone... I will try it again and/or get the deb file. I will let you know shortly.
In that case, also check that in Software & Updates that your Download from is set to Main Server.
Always be on Main Server.
The regional servers are supposed to hold all the same packages as the Main Universe... They don't.
Feel like Im going around in circles here -
Im hooked up to Ethernet cable now...
Retried the original commands you sent. This time they did appear to download the drivers. Rebooted. Still no wifi.
Went to the Updates. Changed source to Main. Looked for drivers - this time it came up with both the Broadcom and Nvidia drivers. Looked promising. Applied changes. Rebooted. Still no wifi.
went looking for the driver link you sent. Downloaded it and clicked. It comes up with an Install buttom - shows me what it will install. i click on Install. It shows a line that says Installing 0% but it wants my password to authenticate. I enter my password and it just goes back a screen to the Install button. So its not letting me manually install them...
I will keep trying. Thanks for all your help so far.
No need for the .deb, you already installed via terminal.
I think for now, we can focus on not the drivers but Modprobe.
You may need to remove the driver from the Module Prober and add the Broadcom driver.
modprobe -r b43 bcma
modprobe -r brcmsmac bcma
modprobe -r wl
modprobe b43
sudo nano /etc/modprobe.d/blacklist.conf
And
blacklist brcmsmac as well as blacklist wl then Reboot and test.
Okay so I finally gave up and went to bed, and when I came back I reinstalled Zorin core. Once it loaded up it had the Broadcom drivers already in and wifi was available. So you guys might find that interesting... no wifi on 15 Lite but Wifi on Core 16. Same computer. Maybe a quirk with MacBook Pro installs.
I still have no screen brightness controls but my screen is okay ish. I can live with it. I wouldnt have it super bright anyway. And I'm wondering if again this is a quirk of Core 16.
And thanks again for your help.
Those are old school wifi dongles? Like back in the olden days? Cool.
But how do I get brightness controls back? I haven't had brightness controls in 15 Lite or 16 Core with my MacBook Pro.
(Note: I do have brightness controls with the same install on MacBook Air or my old Gateway Windows machine)
Oops, I misunderstood that you did have a brightness control in Zorin 15.
[edit]
Video from 2016.
This might help:
@webtasmo Did the solution suggested by @FrenchPress work?
Unfortunately no it didnt work. I even tried adding the exit = 0 as well, both times rebooting. But nothing.
Just so you guys know, the other controls on my mac work such as volume control and keyboard backlighting...
Just so you guys know I finally got the wifi working on Zorin 15 Lite. I followed the instructions here - networking - Installing Broadcom Wireless Drivers - Ask Ubuntu
Still working on the brightness controls though...
You may try the grub parameters that worked in this thread:
"quiet splash i915.modeset=1 acpi_backlight=vendor acpi_osi="
