Screen Brightness Upon Logging In not Changing After Kernel Update from 7.0.0-38-generic to 7.0.0-42-generic on Lenovo Legion 5 15AHP11
Hi everyone!
This forum has been helpful in the past when I had doubts while using Zorin OS for 2.5 years, hence I'm here as I'm in a bit of a pickle.
This is quite lengthy as I've done my best to describe the issue I'm facing right now to the best of my ability so we can come with a solution and help others who may have the same.
NEW LAPTOP TECH SPECS + KERNEL + DRIVER VERSION
Laptop Model: Lenovo Legion 5 15AHP11 (Gen 11, 2026)
CPU: AMD Ryzen 7 250 + Radeon 780M (iGPU)
Discrete GPU (dGPU): Nvidia GeForce RTX 5060
Windowing System: Wayland
Zorin OS Version: 18.1 CORE
Kernel: 7.0.0-42-generic
Nvidia Driver Version: 595-open (proprietary + tested; Additional Drivers from Software and Updates)
Nvidia Power Profile Mode: On-Demand/Dynamic Graphics
Firmware/BIOS Version: T2CN33WW
OLD LAPTOP TECH SPECS + KERNEL + DRIVER VERSION
Laptop Model: Lenovo ThinkPad E14 Gen 2 20TA003FAD
CPU: Intel i7 1165G7 + Intel Iris Xe Graphics (TGL GT2) (iGPU)
Discrete GPU (dGPU): Nvidia GeForce MX450
Nvidia Driver Version: 595 (proprietary; Additional Drivers from Software and Updates)
Firmware/BIOS Version: R1EET51W(1.51 )
HOW THE PROBLEM MANIFESTED
My usual routine is to power up my laptop, check for updates in the Software Store and Terminal, and execute the updates if any.
On my Legion 5, I first tried Zorin OS 18.1 via USB, it went well, and after a day I took the time to do the disk partitioning (I freshly installed Windows 11 to remove bloat and kept it as backup) and the complete Zorin OS installation was a success (.iso file wasn't corrupt as per the checks). After installation, I pulled in the latest updates from the Terminal that updated my kernel to 7.0.0-38-generic, and later picked Nvidia driver v595-open because v595 and v615-open didn't make my dGPU visible in system info and with the nvidia-smi command. I removed software packages that I didn't need from the Software Store.
Playing Warframe from Steam (Proton v8.0-5) has not been an issue since installation and applying any updates. One thing to note is that I didn't fully transfer my personal files to the new laptop because I've heard that branded gaming laptops can be a bit finicky so I went with the Legion 5 since Lenovo makes them work well with Linux and I do own a ThinkPad E14 Gen 2 and didn't face serious issues, just good working experience. I've also heard that when users with dual-boot setup update Windows 11, it messes with the GRUB bootloader, and that's another reason I didn't transfer my important files yet. I plan to accumulate the updates for 2-3 weeks and see what happens. Don't worry, I've disabled Secure Boot (UEFI) and Fast Startup (Control Panel) and left them as is to avoid problems.
One fateful day, I booted up the Legion 5, ran some updates from the Terminal this time having the kernel updated to 7.0.0-42-generic, restarted to apply the new kernel, did sudo apt autoremove command to remove the old 7.0.0-38-generic, restarted again, logged in, found out my windowing manager got switched to X11 so got back Wayland, and tried to lower the screen brightness with my F5 key only to see it not respond, even with the UI slider. That's how I knew I got this problem. As far as I know, I didn't get error messages when the kernel update happened. It all seemed normal to me.
TROUBLESHOOTING + OBSERVATIONS
Here's what I noted along the way regarding the screen brightness being bugged out on my Legion 5:
  • I tried doing 2-3 Restarts but with no success to regain control over screen brightness control
  • On X11, both iGPU and dGPU were recognised by the system (System Details in Settings) and screen brightness can be changed with the slider and Fn keys with no issues as long as I used v595-open Nvidia driver, but X11 felt laggy and made gaming rather slow and utilises 100% of my dGPU, and that doesn't happen on Wayland
  • I tried v615-open Nvidia drivers, but couldn't adjust the screen brightness, hence I'm sticking with the reliable v595-open driver
  • I did some searching and came across a user from Fedora Discussion who had a similar-ish issue but same brand of chipsets, i.e., AMD + Nvidia setup in their Legion 5. Link: [SOLVED] Brightness Control Not Working - Lenovo Legion 5 15ARH05 (Ryzen 4800H + GTX 1650) - Fedora Discussion
  • There was a 5th verification command echo 128 | sudo tee /sys/class/backlight/amdgpu_bl0/brightness that I ran with the same setup because that's what I prefer to use, and the screen dimmed immediately, yet couldn't be adjusted with either Fn keys and UI slider
  • In iGPU and dGPU only modes that I changed to via UEFI menu, the screen brightness levels can be changed, except the dGPU only had a max brightness that looked somewhat dimmer than the iGPU only and Dynamic Graphics modes, but they can be manipulated either with Fn keys or UI slider
  • Funnily, my ThinkPad didn't face such problems at all despite having the same kernel update, except it uses a slightly different Nvidia driver version and brand chipset combination (mentioned in above specs section of this post), and it uses intel for the backlight function
RECENT INTERESTING OBSERVATIONS
3rd Nov: I booted up and logged in to my Legion 5, Wayland and same 7.0.0-42-generic kernel and v595-open driver, the screen brightness was adjustable via Fn keys and UI slider. Weird, and that's the 2nd time I'm seeing this. After a restart, I lose control over the brightness adjustment as usual. Not sure what's causing this kind of behaviour.
4th Nov: When I get to the Log In screen after Restart or Log Out, specifically these after clicking on the Power Off button, adjust the brightness with Fn keys or UI slider from there, log in, and it remains stuck. Example: I Log Out, I move the slider to the middle for medium brightness (darn bright as it's OLED), log in and it stays at that set brightness. Also, when I attempt to adjust the brightness, the UI slider and the brightness bar that appears at the screen's bottom centre show it at less than a quarter mark when it's supposed to be in the middle. Same result as before.
FINAL THOUGHTS
The Fedora Discussion link given above provided 5 verification commands that I ran to see what's up in my Legion 5 in Dynamic Graphics mode, all came out normal except I couldn't raise the screen brightnes with Fn keys and UI slider after running the screen dimming echo command.
In 'Step 4: Add Kernel Parameter', I did see a similar command in other sites and forums in slightly different variations, but I didn't implement it as I don't want to mess with the GRUB config stuff until someone weighs in on it.
So yeah, I did my troubleshoot as much as my average-self can and found a possible potential solution to the problem, and I would like some guidance in this situation. Let me know if there's any doubts.
Thank you in advance! :slight_smile::sparkles:
Because the newer Machine has relatively recent Hardware, maybe a newer Kernel could offer better Support. So, You could try it with installing the Liquorix Kernel and see if it behaves more stable.
To use this Kernel, Secure Boot has to be disabled. To get the Kernel, first add the PPA via Terminal with:
sudo add-apt-repository ppa:damentz/liquorix
When done type:
sudo apt update && sudo apt install linux-image-liquorix-amd64 linux-headers-liquorix-amd64
After that reboot and on the GRUB Menu on Startup choose ''Advanced Options'' and there the one with the Liquorix Kernel. Then log in and test how the Screen Brightness behaves.
Ah okay!
I did wait for the chipsets to age a year so Zorin OS can provide better support for them, and their most recent blog post did say 18.1 has improved hardware support. Guess I should've been a bit more patient :sweat_smile:
Nonetheless, I shall give it a shot in leisure and share the results over here.
Thank you for the quick response :+1:
I use the afore mentioned kernel. Works well here is current kernel number
also on my monitor i have an eye saver function,maybe see if yours has this as well
Alrighty! That looks reassuring and I'll take note of that :+1:
I believe the eye saver function would be the Night Light thing, right?
I'll let y'all know when the Liquorix Kernel is installed and everything acts normal, hopefully :crossed_fingers:
Thank you for the reassurance :+1:
Umm, mines built into the monitor when i bring up its setting on a switch on the actual monitor. I have a samsung 35 inch curved monitor
the night light effect when I turn that on does look alot like my screen using my built in monitor settings tho with slider all the way to left
Ah I see. I'm just a Lenovo Legion 5 laptop user and I don't have a desktop computer (maybe someday). What I do know is that the screen on my laptop does have some blue light reduction built-in to it to reduce eye strain :slight_smile:
the nightlight does help alot tho i turned off my monitor setting then turned on nightlight and used slider to help reduce brightness and yes I have a 12 core desktop....... :innocent:
Regarding the Liquorix Kernel, I've done some digging on IT'S FOSS and the official website of Liquorix, and found that it can be installed with a single command which is this:
curl -s 'https://liquorix.net/install-liquorix.sh' | sudo bash
I guess I can use this single script to do install, right?
My Secure Boot is already off, just a heads up :slight_smile:
Lastly, if the installation is a success and everything works as it should, can I run sudo apt update && sudo apt upgrade to fetch updates including kernel updates like I used to before? I just hope nothing breaks severely that it'll affect my work :crossed_fingers:
I forgot to mention that I use my Legion 5 laptop for gaming, practicing web design on Lunacy and the usual browsing the web, watching shows and videos. That's what I normally do on my laptop. I don't even play games at ultra high settings and get too picky with it as I don't want to wear out my hardware by being reckless, hence I turn some features on and off as a way to customise it.
Thank you for your help! :+1:
You can use this, too yes. What it does is, it checks what System You have to add the fitting Repo. Because You have Zorin 18 what is based on Ubuntu 24.04, it would add the PPA what I have wrote down. But yes, You can use the Script, too.
Yes, You get then Kernel Updates like before - but then for the Liquorix Kernel and the default one. I have that, too.
If you want to install the PPA its
@wesoliv429 @Ponce-De-Leon
Just want to let you guys know that I didn't forget to update my post over here. The next few days are going to be busy for me, but I'll come back to keep y'all posted.
Have a good weekend! :smiling_face:
I have a desktop so no discrete GPU.
I am not using Zorin these days, I am running PCLOS Debian with Plasma 6.3.6 DE. It has a brightness control applet which you have to make 'show always' in the System Tray entries. Ironically, the night-light applet doesn't show for turning on and off. I guess they want users to set it up to timezone or manual settings to ensure eyes are protected.
Hey!
I did have a look at PCLOS Debian + KDE Plasma set up on your website and it looks quite identical to Windows 10's UI, and I must say that's pretty impressive :+1:
In my case, my laptop is on Dynamic Graphics mode as it has both iGPU and dGPU. I prefer this mode, but the screen brightness couldn't be adjusted. I can see the slider when I open the power menu on the upper right of my screen and the bar indicator at bottom centre that shows the brightness level when I press my Fn 5 and Fn 6 keys.
On the other hand, the night light works perfectly alright and has its own button in the power menu, and I can customise its duration as well.
Hey! I hope you're doing well.
I'm planning to try the Liquorix Kernel coming Monday or Tuesday when I have the time.
Just in case if it doesn't work for me, can you tell me how to uninstall the Liquorix Kernel safely?
Many thanks! :slight_smile:
First, You boot on the GRUB Menu back in the old Kernel. Then to uninstall the Liquorix Kernel type in Terminal:
sudo apt purge linux-image-liquorix-amd64 linux-headers-liquorix-amd64
After that check with apt search liquorix if there is any remaining Packages installed. If yes remove the Package with sudo apt purge [Package-Name]
Then remove the Liquorix PPA with
sudo add-apt-repository --remove ppa:damentz/liquorix
and then make a sudo apt update && sudo apt upgrade to refresh the Sources and check that the PPA is gone.
Hey!
I have an update after installing and trying the Liquorix kernel (7.3.3.1-liquorix-amd64) on this set up:
  • Wayland windowing manager
  • 7.3.3.1-liquorix-amd64 kernel
  • 595-open Nvidia graphics driver
  • Dynamic Graphics/On-Demand mode
The GPUs were detected via System in Settings and dGPU can be seen with nvidia-smi command, but couldn't adjust the brightness with Fn5 and Fn6 and UI slider. So I tried with 615-open driver for Nvidia to see if that can help but it forced itself to use the Xorg nouveau drivers so I try again to apply the 615-open driver, reboot, and the black screen appears constantly saying that the GPU will be locked with nouveau. Luckily, I managed to boot into the usual 7.0.0-42-generic kernel, get the preferred driver back, and all's normal and same as before.
I tried the 615-open Nvidia driver again for 7.3.3.1-liquorix-amd64 kernel, but I got the glowing Zorin logo not transitioning to say Zorin as it stayed glowing for good 2 minutes. I couldn't even login at all.
Right now, I'm back on the 7.0.0-42-generic kernel with my preferred windowing manager and Nvidia driver.
Lastly, for the past 2 days whenever I do 1-2 reboots, I see the windowing manager options in the lower-right of the login screen change a bit like this:
When I know I couldn't adjust brightness after login:
  • Zorin Desktop
  • Zorin Desktop on Wayland (this is selected)
When I know I can adjust brightness after login:
  • Zorin Desktop (this is selected)
  • Zorin Desktop on Xorg
I know that this seems weird and all, but this is something I've noticed and I sort of use it as a tell-tale sign when I can adjust the screen brightness like normal or not.
I'm thinking that I shall stick with my regular kernel since it's not bothering me severely in any way (playing Warframe is good, thankfully) as I can use the weird quirk to see when I can normally adjust screen brightness until Zorin OS releases a kernel update that can fix this, hopefully :crossed_fingers:
I forgot to say one more thing, apologies!
I checked under System Update in Legion Space on the Windows 11 side and found that there's a firmware update called T2CN43WW. My current firmware version is T2CN33WW so I checked online and found it on the official Lenovo website for the 15AHP11 to get any info on it. I don't have any issues so far so I didn't apply the update with Legion Space, and I heard that BIOS updates are only done out of necessity and the last thing I want to do is brick this brand new laptop. So yeah, I wanted to add this in.
Thank you for your help and suggestions!
Interesting. Both ''this is selected'' Options are Wayland.
The first Variant:
Is mostly when You install Zorin with Nvidia Drivers.
And this:
is without installing Nvidia Drivers during Installation.
When that is fine for You for now, good. Then only other IDea what came to my Mind would be to try a Gnome Extension. But when You can handle Your current Situation, it shouldn't be neccessary.
Yes, that's true!
Honestly, this is such an odd behaviour. My ThinkPad E14 Gen 2 with Intel + Nvidia MX 450 don't behave like that, but with the Legion 5's AMD + Nvidia RTX 5060 setup, it's just a little weird and unexpected if you ask me.
I'll definitely keep my hands to myself and wait for a decent kernel update that could support my hardware and fix this.
I wonder though, could this be an OS thing or my hardware that's causing this little inconvenience?
Also, today morning I did a restart so I can pick the 7.0.0-42-generic kernel to start removing the Liquorix Kernel with your instructions, but in the GRUB's Advanced Options section, my 7.0.0-38-generic kernel disappeared. The funny thing is I didn't give the permission for its removal :sweat_smile:
Something tells me I may have to do a fresh reinstall of this OS...who knows, it might fix it.
Thank you for your patience and the help! :raising_hands::sparkles:
