Hello! I have Zorin OS 18.1 installed on my Dell Precision laptop, and often connect the computer to a second monitor. I'm using Wayland
Zorin will remember my fractional scaling settings, but it will often forget the positioning of the screens and reset my placement after a reboot (ex: I set my second screen to the left, slightly higher than the laptop).
How is the external Monitor connected? Do You use any Adapters or HUB's? Does Your Laptop have more than one HDMI/DP Output? Does the Screen stands like You have set it up in the Settings?
