After reaching login screen, I have barely enough time to type the password. Screen goes solid dark, while system is still operational. I can restart monitor to get ~5s, but it goes dark again.
Booting into previous kernel does not help.
What does work (sorta):
booting into recovery mode, then just pass through to resume boot (Enter + Enter)
It works except the Gnome animations are all gone, video playback is choppy and external GPU is not being shown by Mission Control (flatpak app similar to Window Task manager).
I am curious if I can recover from this without being forced to full OS reinstall.
Hello and welcome,
I had the same problem and it come from the linux-firmware update who get regression.
I did this, so go in recovery and try to downgrade :
Just out of curiosity - since I tried to downgrade the firmware on Linux Mint once, too, because of fan problems after an update, and it didn't fix my problem.
Is the initramfs also updated by a reboot, or do you have to run the command sudo update-initramfs... explicitly?
If so, now I know why it didn't help, but no one told me when I asked in forum.
You need to run the command.
Why ? because the bad version of linux-firmware did it when you install it, and if you downgrade, you need to 'register" this version
Thank you for the information! I hadn't run that command. Now I'll know to keep that in mind in the future (I hope I don't forget it next time because it doesn't happen that often, after all).
This also fixed my issue after recent update with screen going half blank, at log in screen, then completely orange shortly after login. My GPU is a RX 6900XT. Hopefully not a widespread issue with RX 6000 series cards. Appreciate all who posted in this thread.
As I don't know what is your original problem and what hardware system you have, I can't answer you.
So open a topic and expose what problem you encounter because this topic is closed...
