Scrolling issue
Hi! When scrolling i can see the middle part of my laptop screen flickering... I did not have this with windows.... Could someone help me how to fix it? (Im also considering switching to Fedora....)
You could test if this happens on Fedora, too.
For Zorin:
  • Does Zorin run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
  • How are Resolution and Refresh Rate set up?
  • Is Fractional Scaling active
  • What Graphics Card do You use? If Nvidia: What Driver is in Use?
X11 But I already switched to Manjaro :sweat_smile:, anyways: Thanks for your help!
