Second Drive is not shown in Synology Drive list
Hello, Everyone. I was a Windows user and recently switched to Zorin OS. As of now, everything is going well except for one problem. I have two drives on my laptop: one is an NVMe SSD on which Zorin OS is installed, which is working perfectly fine, and the other is a standard hard drive (shown as an externally mounted drive on my laptop).
Problem: I have installed Synology Drive Client to sync my data from Synology NAS 220+ but the problem is when I am configuring it, it gives me the option to select the directory where I want to sync the data. Unfortunately, the second hard drive is not visible on the list (location: mnt/Warehouse (warehouse is the name I have given to drive)). My SSD drive can't sync data because it's large.
I have attached some screenshots which might help you.
Hello,
Which package system did you install Synology under? If it's a flatpak (as I suspect), you need to install flatseal to set up the permission of Synology.
Thank you Bhai, Your prompted response to my query convinced me to invest in Pro adition of Zorin OS. I am now a Zorin PRO user. Thank you!
