I put a command fwupdmgr security
Here i have a some a couple bleeding or bugs in kernel security Intel.
Were you running firmware updates or have you run firmware updates recently?
Mostly this red describe are bleeding is Intel guard, propably processor.
Read up on this vulnerability - don't feel too bad for having some older stuff lol
Do you share any devices with anyone? If not, probably don't have much to worry about. Just run a firewall, on your router (would suggest OpenWRT / DD-WRT) as well or separate (pfSense, etc.) and VPN if you can. RiseUp-VPN is in the snap store, free to use - but is recommended to donate. I take as much advantage to free security as much as I can; ClamAV as well on my Linux machines.. This is a crazy scary vuln though. Will have to follow this to see how Intel proceeds with a solution..
If I watch Youtube, they might be able to deduce what kind of person I am from the content of videos. ![]()
Everything collect your data. In mobile when you lut a service code. IT Tiger what you using and how long.
