https://packages.ubuntu.com/bionic-updates/amd64/linux-headers-4.15.0-54-generic/download
Download the .deb files into One Directory. CD a terminal into that directory and run
sudo dpkg -i *.deb
To install all at once.
sudo dpkg -i *.deb
Done it. After rebooting, 4.15 is available and loading process is ok (logo and name, no tearing!!!!! :)) but it showed
At the prompt below the busybox error, type exit
it should show the actual errors.
Please relay them.
when I type "exit" it shows again the same text in console, as in my previous message.
See if it will accept the command:
sudo fdisk -l
This should list your Drives.
It should look like /dev/sdaX
where the X
is a number. For example, /dev/sda1
Identify the Drive.
Then use that to run:
sudo fsck /dev/sda1 -y
Replace "sda1" as needed by the drive you identified above...
message: "sh: sudo: not found"
checked on www: "Please note that sometimes you don't see any errors after typing the exit
command. In that case, try to run fsck
on all filesystems."
Try without sudo
fsck /dev/sda1 -y
Replace sda(1) as needed...
I can not list drives using fdisk, therefore I can not use fsck (I tried with fsck /dev/sda1 -y, but I got error2).
There is not specified drive/volumen to fix.
Will it accept any commands?
cat /etc/fstab
2 days ago I was doing a deep research about how to fix "busybox" screen by trying different kernel versions. It didn´t work.
I finally decided to install linux mint 19.2 and I managed to update to 19.3, but not possible to 20.2 that I wanted to try. (the upgrading process was very slow and there was an error during the process and I had to use TimeShift to revert the changes and use the last working version).
Zorin OS has not the old versions of kernells that my laptop requires, it is a pity....
Thank everybody for your help!
Marked Solution. 362
