Set Up Wallpaper for Lock Screen
I successfully finished doing that vro can you please tell me how can i set lock screen wallpaper like we do in other os(windows etc)
I created a new Thread for You because it is a new Topic.
So, Lock Screen Wallpaper. You can use gnome-tweaks for this. To install it, type in the Terminal sudo apt install gnome-tweaks and after that open it and go to the Appearance Tab. And there it is on the right Side:
Tried this vro it's not uploading it's still the same
Hmm ... Okay, You could try to customize it with a Gnome Extension. There would be these 2 that I found spontaneously:
To install them, go to Gnome Software Center and install the Extension Manager:
When You have installed it, open it and go to the 'Browse'' Tab and search for the Extensions and install them.
Either way it doesn't work mate thanks for ur efforts thoo.. :smiling_face_with_tear:
I Guess I don't really need a lockscreen anymore
