Because I am not a bigshot business that needs an enterprise grade network, and the latest and greatest tech like LTT always seems to gotta have, this is all I need.
This is a nifty box enclosure that can take up to 4-3.5" hard drives in it. However, the power brick for it only supports 60-watts total output, so I don't recommend you populated it with 4 power hungry 3.5" mechanical drives.
Truth be told, I thought I was going to populate it with 2-drives at least if not 3 in its life that I've been using it. But I still only have the single 2-TB WD BLACK 7200 RPM 64MB HD that I've had in it for like 4-years.
I used to run it 24/7, back when I was accessing it more. Basically, I've been using it like a NAS storage. And if your running a gigabit network, its plenty fast enough for home users. But, I don't access it as often as I used to, so, to save motor drive life on the HD, I decided to power it down when not in use.
I have it connected up to a USB 3.0 hub, its goes as fast as the HD goes. If I had a SSD drive in there instead, it would obviously be faster still. But for permenant storage, you can't really beat the cost of a 2TB mechanical.
Cause I just looked them up, Western Digital Black 2TB SSD's are like 200 dollars right now, NVME SSD's just a hair above that. So yeah lol.
