Setting VLC to automatically open selected file types in Zorin Pro
Hi
In the last few months decided to look for alternatives on a 2013 iMac as it was no longer updating etc.
Sure there are ways around it, but fancied a change :slight_smile:
Stumbled across Zorin and here we are now with Pro paid for and installed without major issues
A few things to get my head around like @ and " are switched on the keyboard, and it's no longer CMD but CTRL, but I'm sure I will get there :slight_smile:
Earlier this evening I needed to view videos from a dashcam
For each file I had to navigate back through VLC and file open etc etc
Is there a way (like I remember from many years ago) where you can associate a particular file viewer (ie VLC) to be the default for opening specified file types, so I can click on them at source and they will automatcaly open in VLC
Chris
When You go to the Settings and there to the 3rd Option from the Bottom (Sorry, I don't know the English Name for it). There you can adjust that:
Perfect :slight_smile:
Thank you
