This question is almost 3 years old, unfortunately there is still no possibility. Maybe there is a non-gui possibility by now in Zorin17?
I believe uPower does have this ability:
Both
systemctl hybrid-sleep
and
systemctl hibernate
result in
Failed to put system into hybrid sleep via logind: Sleep verb "hybrid-sleep" not supported
Failed to hibernate system via logind: Sleep verb "hibernate" not supported
I won't follow the instructions for adding Kernel parameters on my daily Zorin system, but would be happy if the team would add this option by default in future releases.
Ah... I see...
That explains a lot.
In this case, I am going to move this to the Feedback sub-forum.
