This my 2nd trouble when try this zorin, after first try on Zorin 15 finally I test to Zorin 16... it's a nice looking but suddenly Settings app cannot open... and say Settings is not responded
I already try to remove and install again but with no luck, with this command,
Already do any update...
Just try Mac OS look and Windows 11 look and when I open settings to back to Mac OS again, settings is not responded that's an option Wait and Force Close
I had similar issue, but in zorin os 15.3 lite. I changed icon theme to Fluent and zorin dock gone, so I could open xfce settings in terminal just with sudo, but I couldn't change icon theme there, so I deleted Fluent icon theme in /usr/share/icons and everything worked fine.
Yes, I try it just like the first post and then I remove it...
Finally I know what the culprit is... Display on Settings...
If I open Display on Settings and it shows not respond... so I restart it and open Settings again because the last time settings open in Display it shows again Not respond. So I have to force close to quit, and then I open Wifi Setting in Right Top Bar and settings could open just fine...
I suspect that because Variety app... so I remove Variety and open Display on Settings can open with no problem...
Hmmm...
