Hi guys, I think I messed up with my system. My Zorin Connect doesn't work, and I am unable to change the cursor. It's only been a few weeks since I switched to Zorin 17.3. Should I format my PC and switch to Zorin 18, as there is no important data in it right now?
it's up to you. You can give 18 a try, if it doesn't go your way, you could always install 17.
With 18 comes newer drivers and libraries to the system, so it might swing in your favor.
That is Your Decision. When You planed to install it anyway because of Your Issues, You could of Course directly install the newer Version.
