Hello, everyone,
How can I turn off the query if I want to shut down the system using the on and off switch?
Best wishes, Steven
Hello, everyone,
Best wishes, Steven
Hi and welcome to the forum
I changed the category of the thread from Customization to General Help to attract more volunteers.
The only answer I have that may do what you want is this...
Click Zorin
icon: SETTINGS: POWER: POWER BUTTON:
StarTreker
Your Tech Support Guru
Hello and thanks for the solutions!
After "pressing" the power button, I have the display (see photo) and I don't want to see it, I want the system to shut down directly without display or countdown.
Greetings Steven
gsettings set org.gnome.SessionManager logout-prompt false
To reverse it, set to true instead of false.
thank you very much
thats is the solution
greetings Steven
